Rona318ti
BMW vin numbers
Hi
Can anyone shed any light on the vin number of the 1997 318ti vin number.
My number is WBACG82090AS82943, car is ex Japan.
Its the 10th number I have a problem with, all the information on the net says that the 10th number is the year code, but BMW do not use I,O,Q or 0 (zero), but mine is a zero and comes up as year unknown or incorrect number. The AS82943 number corresponds to the car when that it checked on the other sights.
I got the number off the ownership papers, and the back of the engine bay, just below the driver’s window wiper, is there another place on the car where the number is stamped???
Curious
Ian
Guest Andrew
I get this information on the car:
Chassis number AS82943
Vehicle code CG82
Series E36
Model 318ti ( 318ti M44 )
Body type compact
Catalog model ECE
Production date 1996 / 11
Engine M44
Transmission Automatic
Steering Right
Catalyzer YES
Additional Information for Vehicle code CG82
Production FROM : 1995/07/01 TO : 1997/08/31
Engine M44
Engine Oil 5.00 Liter
Transmission Model A4S 310R
Transmission Oil 9.00 Liter
Rear Axle Oil 0.90 Liter
Coolant(w/o Air Conditioner) 6.50 Liter
Coolant(with Air Conditioner) 6.70 Liter
Brake fluid 1.00 Liter
Remarks :
Automatic transmission: lifetime oil filing
From http://www.bmw-z1.com/VIN/VINdecode-e.cgi
Andrew
Thanks for the info. I found the same information. My question is about the 10th digit, it's a zero and as the table below shows zero does not corresponds to a year, so why does my vin have a zero for the 10th diget rather than a 'T'????
'10th Character: The 10th character in your BMW's VIN tells you the model year. (This varies somewhat among car manufacturers - see the chart in the "Here's How to Find Your Car's VIN" section below for specific locations by car make.)
VIN Character - Model Year Codes
1971 1972 1973 1974 1975 1976 1977 1978 1979 1980
1 2 3 4 5 6 7 8 9 A
1981 1982 1983 1984 1985 1986 1987 1988 1989 1990
B C D E F G H J K L
1991 1992 1993 1994 1995 1996 1997 1998 1999 2000
M N P R S T V W X Y
2001 2002 2003 2004 2005 2006 2007 2008 2009 2010
1 2 3 4 5 6 7 8 9 A '
The table comes from :-
http://www.autohausaz.com/bmw-auto-parts/b...on-numbers.html
Cheers
Ian
WBABE520X0EK81891 i have the same thing in my vin number, 10th number a "0" or a "o", i dont know what it means, cant say i really thought about it till now :blink:
Guest Andrew
Andrew
1 2 3 4 5 6 7 8 9 A
B C D E F G H J K L
M N P R S T V W X Y
Cheers
Ian
Probably because that is not how you decode the VIN. The information is wrong.
