Coffee&Doughnut 0 Report post Posted August 31, 2006 Hi, Will these fit an E32 735il, I am uncertain about the offset; Front Tyres and Rim : 225/50/R16; 7J, Offset +33, PCD 114 (5 stud) Rear Tyres and Rim: 225/50/R16; 8J, Offset +33, PCD 114 (5 stud) Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted August 31, 2006 Negatron. wrong stud pattern, and the offsets are all cack. Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted September 1, 2006 Spargo said: Negatron. wrong stud pattern, and the offsets are all cack. They looked good, split rims too.Oh well, thanks for that. Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted September 1, 2006 You NEED a pattern of 5x120, and offsets of around 15-20p. What were they off? That'll clue you as to whether they would have fitted. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted September 2, 2006 Spargo,s spot on,std offset is 20mm and hub dia is 72.4.Many aftermrket wheels will have a hub dia of 74mm as does any E39 5 series wheel.Most any other 5 6 or 7 wheel will fit your car.The extra hub dia can be cured with a shim or hubcentric ring. Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted September 2, 2006 Thanks for the input, I found this link which is pretty straight forward http://www.nice-wheels.co.uk/BMW.html Originally I thought I would just stick with the bottle caps, but they are really dull looking and dont fill out the arches ,problem is I bought a brand new set of C-drives. Quote Share this post Link to post Share on other sites
