p1_m3
E36 M3 - clutch bite point
Just wondering if the clutch starts to bite early in the pedal travel whether thats an indication of it needing replacement?
Any good hints to work out if a clutch needs attention, any sounds etc?
thanks guys :)
If it bites early then it usually means that the clutch is in a healthy state - it's only when it's bitting late on the up travel of the pedal that you should be worried about. Although if I am not mistaken the M3s have self adjusting hydraulic clutches (at least on the E46 M3s they are), so technically the bitting point should remain reasonably similar throughout the life of the clutch disc.
