Cressidom 0 Report post Posted September 19, 2006 I have this problem..with my car when sometimes the throttle is depressed it seems that the 'signal' is not going thru and there's a hesitation..so will need to rev it up and then release the clutch to get going. I also got the problem with the 'bouncing' idling..sometime after running a while and shut down and start up later (when still hot) The rpm jump up and down and in some cases the engine stalls.IF i apply some pedal to 'even' out..then it's ok. BUT on shuttin off the A/c and idling becomes like a broken exhaust..(boop bup bup etc)... Thought it was the MAF..swapped a buddies one..and had the same problem. I"Ve been told to check oxy sensor,crank , cam or throttle switch (TPS ). Any with advice tips..greatly appreciated. Cheers Dom Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted September 19, 2006 Not sure if your motor has an idle control valve (ICV), but if it does, clean it! Bet you its gummed up and sticky. Carb cleaner, de-greaser, petrol etc will clean the guts of it. No scratching though! keep those surfaces nice and smooth... Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted September 19, 2006 yep hes right, and vacumm leaks are a biggy as well i hear. and thermostat engine temp sensor and coolant sensor. Quote Share this post Link to post Share on other sites
Cressidom 0 Report post Posted September 19, 2006 OK..interesting... have cleaned out the T/Body..ISCV...about a week ago...still no change...Vacumm leaks maybe..still sorting out thru the usual places.. Ahh..where's the coolant sensor located - is that the unit in the airbox ?? Thermostat engine temp sensor..hmm.. Ok will check those out as well.. Thanks Dom Quote Share this post Link to post Share on other sites
Cressidom 0 Report post Posted September 20, 2006 Hi Did the MODIC check with the diagnostic thingy today... FAULT code 42 - Mass Air Meter - Fault.. So guess it's that then..time to change the MAF.. >>> what difference will i see when i change it ?? Accelaration ? Idling ? Others ?? Cheers Dom Quote Share this post Link to post Share on other sites
