red e30
Newbie with E30
Hey all, looks like a good group you have here. I hope i can find some info that i need and with a bit of luck help someone else out.
I have a 1988 e30 that i purchased stock as rock about three years ago. Since then it has had a bit of work done to make it a bit more reliable for the car club sprints and motorkhanas that i do.
cheers,
cam
Posted Image
Posted Image
mods so far are:
Suspension:
Koni adjustable dampers
Eibach springs
Noltec urethane control arm bushings
Noltec reat shock absorber mounts
Urethane diff mount
Noltec subframe bushings
Noltec trailing arm bushings
Front and rear strut braces
Adjustable front swaybar links
Wheel & Tyrees:
BBS 14inch with Bridgestone Potenza G111
16x7 Performance Minilites with 205 Toyo semi slicks
Engine: (Crappy M40 at the moment)
Free flow exhaust system with ceramic coat extractors
K&N Panel filter
Oil catch can
Brakes:
Slotted RDA rotors
Bendix Ultimate pads
Stainless steel braided brake lines
Interior:
Sparco 4pt 3' harness for track days
OMP suede steering wheel
Illuminated ///M gear knob
Fire extinguisher
Exterior:
De badged
Clear side indicators
Black front indicators
Black kidney grille
Stereo:
Focal speakers
Alpine amp
Alpine head unit
Future Plans:
LSD
Adjustable strut tops
Reiger front lip and splitter
M42 with a bit of work
Velo GP-90 seats
Very nice. Great mod list - doing the right mods for the right reasons. Makes a nice change.
Cheers
Grant
thanks for the nice comments guys. I would love to race it, and will at some stage i will but at the moment i can only afford one car so really not going to happen for a few years.
It needs a bit more power for me to be competitive on the longer tracks for the under 2lt modified class but hopefully a worked m42 will help that department.
I am actually over is Aus. we have a racing series for 325i e30s is this similar to what you guys have? The web page for the series is:
http://www.e30racing.com.au
i really dig it.
what sorta kg the minilites weigh?
really good mods ya done...all the ones that work and none that don't!
welcome
i really dig it.
welcome
Cheers, the wheels are not very light, not sure of exact weight. They are not the genuine Minilite brand that were big in the sixties, they were a magnesium alloy. They are an aussie made wheel that are just an aluminium alloy. I really only went for bigger wheels so i could get a stiffer sidewall and better choice of r compound tyres.
Edited by red e30
