drifty325i
Mtech 1 rubber bumper trim
Hey guys as some of you may be aware ive taken my old body kit off the rear of my car and ive replaced it
with a mtech bumper. But as i have found out the standard rubber trim does not fit correctly (flush) with the
mtech. Does anyone have a good condition one availible? dont want any dings or deep cuts in it.
cheers 0273139025
Riley
Id take it as a no mate.
Seems that way, ive been told the standard bumper trim is the same
Guest Andrew
It's not.
But you make it fit.
It's not.
Might have to, dont think it will be to hard
Guest Andrew
nah - get some nuts and bolts (long skinny bolts) and make your own mounting - you'll see what i mean when it's all apart.
I have fitted the standard trim before with the skinny bolt trick. just leaves a little gap all the way around
