MaXiMuS
e30-sr20DET ???
hello! i need some help.. I want to put an sr20det in a e30 and i wonder if somebody of you have motor mount brackets? do you use gearbox from s14? is it something else i have to have in mind? :wacko:
Guest Andrew
use search -
there are 2 or 3 members who have SR20s in thier E30s.
And yes there is a lot more to think about - brake boosters etc etc. It's hardly bolt in.
Andrew, can you move this thread into another section please and keep this forum for the race series only. Cheers Conrad
yes yes no matter how much you plan it you always run into problems haha
at the moment mine is getting brake and fuel lines from one side of the car to the other without getting too close to the exhaust.
rear brake lines will be run in the cabin of the car as the booster and master cylinder is in the cabin also (where the glove box normally sits) and running the front lines thru the inner guards etc etc
have a look in a few of the sr20 conversion threads on this site to help guide you thru it all, there is about 4 on here i think
