Guest Ari Gold
E36 M3 box
Guest Spargo
5 speed out of an M roadster.
why? cheaper dogleg alternative (1:1 top I think?)
Edited by Spargo
Guest Andrew
yep
your 3:64 diff will make the gearing really short though.
you sure its 1:1 top?
anyway...you WILL need to change diff...yours is 3.73? mine with 3.23 is bordering on too revvy for long trips...taupo was suck
Guest Spargo
Yea its a 3:73.
Trent and Stu recomment sticking with the 260 compared to the ZF 5-speed, mainly due to design flaws and they are difficult to shift under heavy loading and weight transfer, the shift feel is crap, and they are a bit heavier than the E30 Getrag.
Also, I'm guessing that the shifter would also be sitting at an angle, and i'd need an E30 M3 driveshaft too.
I guess i'll just rebuild my 260 then :ph34r: Anyone had this done, whats it going to cost me?
Here are the ZF specs:
First 4.21
Second 2.49
Third 1.66
Fourth 1.24
Fifth 1.00
Reverse 3.89
Clutch Size (mm) 240
Final Drive Axle Ratio (:1) 3.23
Would also be damned tricky finding a 3.23:1 E30 LSD.
