lilme 0 Report post Posted November 29, 2006 one of my rear brake lights has a mind of its own, it stays lit up when the car is off sometimes, and its alot brighter than the other aswell, anyone know what is causing this? and how to fix it? Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted November 29, 2006 id say a wiring issue, somewhere its shorting, i can suggest one place to check if not there then good luck, check the bunch of wires running from your boot lid through to your car, they can cause various issues that ive heard of as the motion of the boot opening can cause wear on the wires. Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted November 29, 2006 (edited) I'm not sure if this information helps - but your possitive your not refering to the rear fog light, as this is much brighter than the actual brakelight but should be coming from a different area of the ilght. Edited November 29, 2006 by E30stz Quote Share this post Link to post Share on other sites
