savvi
fan removal
Firstly, replace the 4 bolts you just removed.
Replace the fanbelt and adjust tight.
Then use the 2 attachments below.
The reason you don't remove the pulley and fanbelt is that it provides resistance when you need to give the 32mm spanner a sharp whack with a hammer (borrow Gus' one, he now uses a torque wrench to remove things and hammer is gathering dust... :P ). If the belt is not on, the fan will just spin when you whack the spanner and the nut won't loosten.
Remember it is a left hand thread !!!!
BTW, don't get Gus to do it with his hammer unless you want your fan turned into a kit form one !!
Edited by will
thanks will haha
if you still stuck on, get some big ass waterpump expandable plier things and grab the pulley with them..with appropriate spanner should come off easily
