joshnz 2 Report post Posted December 15, 2006 (edited) I pulled up the drive today, paused for a moment, had my window down (to listen for the noise) and the air conditioning was on, fans click on (you can hear them pretty good) but there is a faint rattle coming from underneath the front of the car around where all the belts are by the fans ... I jacked the car up, turned it on and had a look but couldnt see anything unusual just heard the weird rattling, any ideas what this could be? Cheers fellas! Edited December 15, 2006 by joshnz Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 15, 2006 Does it only do it with air con on? If so, could be belt noise - check tension & maybe try running a dry lube stick on the belt. Could be belt tensioner bearing or air con compressor itself. Quote Share this post Link to post Share on other sites
