Maccin 0 Report post Posted December 18, 2006 Hey fellows, Praying someone can help me out here, My central locking has recently packed itself up. In other words, it no longer works full stop and was working fine until a couple of days ago. Due my central locking now being nonexistent i can no longer get into my boot, as it requires a different key to my doors, one i which i don't have:( Is there anyway to manually open the boot from the inside and what is the most probable course for my central locking malfunction. Any help much appreciated guys, Regards, Macca Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 18, 2006 Firstly check from passenger door lock - if key will fit. Central locking operates from both doors & boot. Second - check for blown fuse - fuse 27. Thirdly check door lock control module, located behind trim in bottom of drivers kick panel - two screws & mounted under a plastic panel. Remove & check wiring plug connections for corrosion etc. - Modules themselves do also fail. Failing that - see an auto sparky. No, not possible to open from inside from memory. I can help with any parts you require. If successful - GET a key cut for the boot also Good luck Grant Quote Share this post Link to post Share on other sites
