sadida20 0 Report post Posted February 9, 2007 Hi guys I have a mint 97 e36 323i auto . i was wondering if anyone had any idea on how much it would cost to change this car to manual? Thanks Quote Share this post Link to post Share on other sites
sadida20 0 Report post Posted February 9, 2007 are all these the parts required Getrag Manual Gearbox to suit e36 325i with m50 motor comes with gearbox shifter Flywheel clutch Crank bolts crossmember front part of driveshaft starter motor slave cylinder Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted February 9, 2007 are all these the parts required Getrag Manual Gearbox to suit e36 325i with m50 motor comes with gearbox shifter Flywheel clutch Crank bolts crossmember front part of driveshaft starter motor slave cylinder your motor is a m52 not an m50, the m52s used a differnt transmission i think Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted February 9, 2007 your motor is a m52 not an m50, the m52s used a differnt transmission i think I thought M50 and M52s could swap transmissions? Someone correct me if I'm wrong. Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted February 9, 2007 your motor is a m52 not an m50, the m52s used a differnt transmission i think I wrecked out a 328 M52 manual [cooked engine] everything bolted into a 320 M50 powered E36 Absolutely no fabrication was required for the swap Quote Share this post Link to post Share on other sites
