sadida20
e36 manuel conversion
Hi guys
I have a mint 97 e36 323i auto .
i was wondering if anyone had any idea on how much it would cost to change this car to manual?
Thanks
are all these the parts required
Getrag Manual Gearbox to suit e36 325i with m50 motor
comes with gearbox
shifter
Flywheel
clutch
Crank bolts
crossmember
front part of driveshaft
starter motor
slave cylinder
comes with gearbox
shifter
Flywheel
clutch
Crank bolts
crossmember
starter motor
slave cylinder
your motor is a m52 not an m50, the m52s used a differnt transmission i think
I thought M50 and M52s could swap transmissions? Someone correct me if I'm wrong.
I wrecked out a 328 M52 manual [cooked engine] everything bolted into a 320 M50 powered E36
Absolutely no fabrication was required for the swap
