m_power 0 Report post Posted February 17, 2007 Do e30 pre face lift mtech body kits fit easily onto face lifts e30s? cheers Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted February 17, 2007 (edited) No. Not easily. Only the skirts do. They mount in completely differing fashions Edited February 19, 2007 by Spargo Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 17, 2007 You can make the front/rear spoilers fit but you need to use the pre-fl bumpers and make up bumper brackets and a few other adjustments. It is a real fiddly job and not worth the effort imo because you age a f/l back to pre-f/l. I have done both conversions.. pre-f/l with f/l kit and f/l with pre-f/l kit, the pre-f/l with f/l kit is by far the easier and worth doing, not the other way around. Will Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted February 17, 2007 You can make the front/rear spoilers fit but you need to use the pre-fl bumpers and make up bumper brackets and a few other adjustments. It is a real fiddly job and not worth the effort imo because you age a f/l back to pre-f/l. I have done both conversions.. pre-f/l with f/l kit and f/l with pre-f/l kit, the pre-f/l with f/l kit is by far the easier and worth doing, not the other way around. Will Will, Get confused with all the pre-f/l & f/l's in that explanation??? Quote Share this post Link to post Share on other sites
will 169 Report post Posted February 17, 2007 hahaha, suppose so! what I was trying to say was fitting a Mtech2 kit to a pre-facelift body is not straightfoward. (but do-able). fitting a Mtech1 kit to a facelift body is a ton of work, and not worth doing. I have done both fittings, so this is my opinion.. still clear as mud..??? Will Quote Share this post Link to post Share on other sites
