mops
WTB: e30 rear swaybar
Hello.
as title says, i'm after e30 rear swaybar.
I'm looking for the thickest OEM one, which i believe is 18mm (plz correct meif I'm wrong).
I'm in auckland.
Thanks in advance,
Mops.
If the thickest OEM is 14.5, then that will be what i have.
I wouldnt be so sure. If you are ordering rear swaybar bushings they ask you what size, and the available ones are (if memory serves me right) 14, 16 and 18mm. and I know for a fact that 325iX oem rear swaybar is 19mm (thats what the boys in states put on their e30's)
once I find out exacly, I'll let you guys know.
14.5mm is the thickest OEM, there is also a 12mm and 13.5mm. The 4WD may have a thicker bar but where are you going to find one??
maybe you are right, maybe i'm confusing front and rear (front is thicker...)
