Grant
Occassional Groan from the car's rear
Gidday
I have noticed a couple of times lately a groan from the rear of my car.
It has happened in this situation:
Driving along normally in 5th gear at 100km/h and then needing to change down into 4th while still accelerating (i.e to go up a hill on the open road).
It seems to be the strain of the changing down, and the acceleration that have caused the groan.
The groan lasts for only a fraction of a second, and the behaviour of the car is fine throughout.
It is not a huge worry at the moment, and only happens occassionally. Just a PITA niggle.
Any ideas?
Cheers
  Quote
I don't seem to have that problem with my 323i!?!?!
Sorry, couldn't help it.
Seriously, Maybe the driveshaft support bearing?? or the diff bearings??
I'd imagine both of those would make a noise all the time though!!
What about your trailing arm or sway bar links??? maybe when you change down it squats a little and groans when the components move??
Guest Andrew
  E30-323ti said:
  Quote
Your a bastard! :D
Guest hizza bizza
BUSTED!!, Its called too many skids Grant :P
I would be hazarding a guess at your diff, but like E30-323ti said I would have thought it would make a noise all the time if it was that
