wtbdeath 4 Report post Posted July 2, 2015 (edited) sold please delete Edited August 25, 2015 by wtbdeath Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted July 2, 2015 can you hold it till BM work shop done the vacuum leak test?I booked 22nd this month as earliest I can get. thanks Quote Share this post Link to post Share on other sites
wtbdeath 4 Report post Posted July 2, 2015 (edited) can you hold it till BM work shop done the vacuum leak test?I booked 22nd this month as earliest I can get. thanks I will hold it until sombody pays me. EDIT: BTW, are you suspecting you have vacume leak? From PCV system? The common place it would vacume leak is the hose from vavle cover to PCV, usually break at about 5cm around that 90 degree angle thing, if you know what I am talking about. Otherwise, apart from rough idle, the rest of the system would cause oil leak rather than vacuume leak. The hoses on top of intake manafold do break but unless you wiggled it recently, they usually can just stay there fine. Edited July 2, 2015 by wtbdeath Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted July 2, 2015 I will hold it until sombody pays me LOL...like!! 1 Quote Share this post Link to post Share on other sites
euroriffic 600 Report post Posted July 2, 2015 For a 4 or 6 cylinder? My b22 is a sh*t of a thing when it's cold, takes 3 goes to start then runs like sh*t till it's semi warm Quote Share this post Link to post Share on other sites
wtbdeath 4 Report post Posted July 2, 2015 For a 4 or 6 cylinder? My b22 is a sh*t of a thing when it's cold, takes 3 goes to start then runs like sh*t till it's semi warm 6 cylinder I guess, you can pass me your last 7 digits VIN I can look up for you. Quote Share this post Link to post Share on other sites
