Guest reckless
sus shudder
Guest reckless
yeah got a real sus wobble in the back end of the car if you give it a bit of curry,
it starts at about 40km and stops at about 50km i think it could be the drive shaft, any other ideas?
in 1st gear? could be rear subframe bushes...or trailing arm bushes....what do you mean by wobble? a noise? side to side motion? is everything bolted on properly back there (my diff wasnt!) um......cant think of much else right now...what wheels/tyres you running? just out of curiosity
Yup, I was thinking make sure the diff is bolted on tightly. Also, it may sound silly, but have you checked your wheel nuts, and that they are done up tightly?
Are there any strange and unusual noises when this happens? Is the car tracking normally when driving in a straight line on a smooth road?
Good luck
