Blackjesus
Warning Light
hi all,
on my car, a warning light keeps flashing every now and a gain, its the exclaimation mark in a cirle with two lines on the outside. can any one please tell me what this means.
thanks
hi all,
thanks
What car, what colour light?
Arent they the brake linings ?
Check your brake pads as they may be getting low or the sensors may be wearing out. But most likely your pads are getting low. The thing is that is generally agreed that even though the sensors say they are low, there is plenty of life left in them.
THe answer may be to get used to the light for a while, but check your pads to be safe.
On the money martyn.
Although, the sensors often give a false warning when they get wet. Check your pads, and if they are fine, get used to the light (or remove the bulb)
Edited by bravo
