allan
angel ring's
Hi all. Not sure if this is the correct place but here goes. how does one remove the bulb which illuminate's the angel rings.<_< have tried pulling it straight out, pushed/ turn it but still can't get it out. it,s recessed and difficult to get hold of the bulb. it's rated at 12volts 10watts so would it be ok to increase the wattage or would i course another problem by doing that :unsure:
Would advise against putting a bulb of a different wattage to stock, may melt the plastic around it long term due to excessive heat. I remember when I removed the angel eye bulb from E39 headlights, I just turned the whole reflector bowl that it sits in and took it out that way.
