entscheidend 0 Report post Posted April 2, 2007 Is there a thread or does anyone know what I missing here ... I cant seem to adjust the volume on this car, not sure if it is focked or if I have a pressed something. When I got the car the stereo worked fine, now it is set to the same volume and cant be changed. The knob only works now to turn on and off (push in and out) This is the model without the TV/SATNAV, just the basic BC/stereo with tape player above. Anyone have a suggestion? Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted April 2, 2007 Is there a thread or does anyone know what I missing here ... I cant seem to adjust the volume on this car, not sure if it is focked or if I have a pressed something. When I got the car the stereo worked fine, now it is set to the same volume and cant be changed. The knob only works now to turn on and off (push in and out) This is the model without the TV/SATNAV, just the basic BC/stereo with tape player above. Anyone have a suggestion? I have a similar problem where the volume knob has a mind of its own. If i am cruising along with music playing, i find myself talking louder and louder to a an occupant as movement/bumps increase the volume. Hard braking causes the volume to go down... when you turn the volume knob, can you feel it 'clicking' as its moved? mine doesnt, and i think this is why my volume does what it likes... if it doesnt click, then it may be badly worn, or the contact points need a thorough cleaning... I recommend having a chat to jochen on these forums, he is a genius! Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted April 2, 2007 Go and get a new volume knob from BMW, same thing happened with my dads 5. Worn knob means it has a mind of its own. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted April 2, 2007 Is there a thread or does anyone know what I missing here ... I cant seem to adjust the volume on this car, not sure if it is focked or if I have a pressed something. When I got the car the stereo worked fine, now it is set to the same volume and cant be changed. The knob only works now to turn on and off (push in and out) This is the model without the TV/SATNAV, just the basic BC/stereo with tape player above. Anyone have a suggestion? I've got some original BMW volume controls at home, I can fit a replacement for you if you want. They do wear out - simple to replace. Jochen Quote Share this post Link to post Share on other sites
entscheidend 0 Report post Posted April 2, 2007 I've got some original BMW volume controls at home, I can fit a replacement for you if you want. They do wear out - simple to replace. Jochen Thanks Jochen, i have just sent you a message Thanks all for your help Quote Share this post Link to post Share on other sites
