entscheidend 0 Report post Posted April 11, 2007 to apply a multi function steering wheel from a E39 to a E36? Is it possible? If I get the wiring right will the E39 wheel be compatible with the OE CD stacker / climate control / lights etc? Has someone done it or know someone who can, i have searched bimmerforums as wheel but there looking too. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted April 11, 2007 good idea, do it anyway, as long as it fits, make your own loom etc and connect to appropriate places, could get tricky doing the stacker but would be easy as doing like simple stuff, just get a multi meter and work out what happens when buttons are pushed! Quote Share this post Link to post Share on other sites
entscheidend 0 Report post Posted April 11, 2007 good idea, do it anyway, as long as it fits, make your own loom etc and connect to appropriate places, could get tricky doing the stacker but would be easy as doing like simple stuff, just get a multi meter and work out what happens when buttons are pushed! Im wondering about the clusters and connections, also maybe a tap into the module boxes behind the glove box? Not sure of how a E39 is set up. I successfully converted my 11 button OBC to a 18 in the 323i, all functions work including Range, consumption, distance and sercret functions. Worth a try guys if your into gadgets Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted April 11, 2007 Definitely worth a try ! If you can do the OBC then go for it Quote Share this post Link to post Share on other sites
BMW POWER 2 Report post Posted April 11, 2007 Try PM'ing "Jochen" on here. Hes got tonnes of experience with nav and steering wheel stuff. Hed be willing to steer you in the right direction I think. Failing that you could go and chat to a BMW mech, they should be able to help! Quote Share this post Link to post Share on other sites
jjs 64 Report post Posted April 11, 2007 Im wondering about the clusters and connections, also maybe a tap into the module boxes behind the glove box? Not sure of how a E39 is set up. I successfully converted my 11 button OBC to a 18 in the 323i, all functions work including Range, consumption, distance and sercret functions. Worth a try guys if your into gadgets What are the "secret functions"?? Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted April 11, 2007 yes, im curious also about these 'secret functions' is it a james bond ejector seat??? id bee keen to give that kinda stuff a try. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted April 17, 2007 to apply a multi function steering wheel from a E39 to a E36? Is it possible? If I get the wiring right will the E39 wheel be compatible with the OE CD stacker / climate control / lights etc? Has someone done it or know someone who can, i have searched bimmerforums as wheel but there looking too. The E39 MFL integrates with the vehicle via the i-bus databus. When you press a button on the wheel, the MFL control unit sends a command down the databus representing which button was pressed. So you need to fit the wheel to a car with the ibus present - which the E36 has only in very limited form. How much functionality you would get depends on whether your existing E36 radio is one with ibus remote control capability - some later models had this. Otherwise, you could make your own interface adapter with a PIC (programmable IC) if you are happy coding software and working with micro-controllers..... a few people in europe do this to add enhanced ibus functionality. Not necessarily an easy project.... Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted April 17, 2007 I agree with Jochen. The bus system would be different, in fact in some early E36s it wasn't even there. You can find more about bus systems in BMWs on www.mp3car.com. Go to the forums. Good luck, if you do succeed, I'm sure many of us want to see the end result! Quote Share this post Link to post Share on other sites
entscheidend 0 Report post Posted April 17, 2007 Thanks Yuen & Jochen ... i think I might give this one a miss, i think because I managed to convert my OBC I thought I could tackle that one...too technical Quote Share this post Link to post Share on other sites
