NL1 0 Report post Posted April 23, 2007 I Hope someone can help.I bought my partner a 1995 318ti Jap import 85000 kms I went in for a wheel alignment only to find the passenger side front camber was out by nearly 3 degrees.They thought it could be a bent strut so I replaced both struts.No Change.I was then told it could be the rear control arm bushes So I replaced the offender.you guessed it no change .Any Ideas anyone. Checked car out totally before we bought it couldn't find any evidence of collision damage.HELP I live in Gisborne and we don't have anyone that I can find clued up on BMWs. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 23, 2007 If you know a panelbeater, get them to chuck it on a chassis alignment machine and they'll be able to tell if it's not right very quickly. May have had a whack and put one of the towers out slightly? Quote Share this post Link to post Share on other sites
will 169 Report post Posted April 24, 2007 If you know a panelbeater, get them to chuck it on a chassis alignment machine and they'll be able to tell if it's not right very quickly. May have had a whack and put one of the towers out slightly? I would second this, a decent panelbeater will have all the specs for proper alignment of the car. He might not even have to put it on the chassis machine, I would suspect that the upper mount for the strut has had a whack/whatever and a simple measurement across the towers would confirm if the gap is too narrow/wide. (will be too narrow if you have excess negative camber). You may have to travel to find a decent one however. A lot of so-called panelbeaters out there are just spare parts fitters with no idea about how to check/align a bent car. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 24, 2007 It will just be the strut tower... they actually bend with a good wack (driving over a curb fast etc etc) as others have said ... its an easy thing to fix on a chassis jig. no big stress .. just a little bit of expense is all. Any good panel beater should be able to quote you. Quote Share this post Link to post Share on other sites
