danutt
new bbs will they fit???
got a set of bbs 17's with 235 45 profile tyres
they say
83 x 17h2
E T 35
not sure if these are offset and rim width and size?
will it fit the 318i e30 1990
i havta get spacers from 4 stud to 5 stud which isnt a problem
some help and advice appreciated:)
they say
83 x 17h2
E T 35
just to add they are the bbs rc 307
thanx
Hot wheels - although 4 -> 5 stud converters are horrible and ilegal.
tyres are oversized, most people run 215/40R17. You'll probably run into problems with them rubbing unless you do some guard work, even then you'll have to get the offsets right.
I'll assume that they are 17x8 with that size tire, if so a ET20 offset would be about right. So you'd want a 15mm spacer.
I don't know about 4 to 5 lug spacers so can't really comment, except I think you'll be lucky to find them under 15mm thick.
allright il sell them haha any takers? they 5 stud unsure of the pcd but they are rc 307 style
interested?
interested?
Can you measure the PCD please?
measured it at 110.58 if thats correct offsets 35 i think
can text me 0211486554 and arrange a viewing for anyone interested tyres are mint
Guest Denny Crane
Guessing they're off a subaru?
I'd bite your arm off if they're 5x120
