B.AMAZD 0 Report post Posted April 25, 2007 hey does anyone know whats the size of the stereo that can fit in a 97 e36 coupe?? im plannin to install a LCD in my car, CHEERS Quote Share this post Link to post Share on other sites
entscheidend 0 Report post Posted April 25, 2007 hey does anyone know whats the size of the stereo that can fit in a 97 e36 coupe?? im plannin to install a LCD in my car, CHEERS You can fit most units in there, Alpine, SONY etc I have found Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted April 26, 2007 It's standard, Single DIN. Anything that can fit Single DIN will fit in there. Quote Share this post Link to post Share on other sites
007_BMW 0 Report post Posted April 29, 2007 hey does anyone know whats the size of the stereo that can fit in a 97 e36 coupe?? im plannin to install a LCD in my car, CHEERS hey, ive just installed new head unit in my e36, it would have to be a single din lcd with inbuild dvd player, otherwise you would have to mount the dvd player somewhere else (glove box,under seat) then it gets messy. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted June 5, 2007 (edited) hey does anyone know whats the size of the stereo that can fit in a 97 e36 coupe?? im plannin to install a LCD in my car, CHEERS Yep, as above. As long as its single din you'll be fine. Goodluck Edited June 5, 2007 by 3 SERIES Quote Share this post Link to post Share on other sites
NVADER30 0 Report post Posted March 14, 2008 My last audio set up used a separate dvd player and tv unit. Both were single DIN size. Tried taking out just about everythign in the front of the car to get them to fit and still look clean. There is a potential spot in the panel above the glove box lock but it would mean losing air con and heat to the front passenger which isn't really desirable. The best option is to head down to Repco and get a DIN expansion unit. Costs about $15 although they probably won't have them in stock. I then mounted my DVD player under the glove box and the tv in the factory slot. Theres a space next to the factory DIN slot to run your wires down to the DVD player (just make sure you keep them away from the heater pipes). This would also work for a stacker/normal head unit set up I guess. As far as double-DIN untis go....You're either rich or dreaming if you want to put one in an e36 Quote Share this post Link to post Share on other sites
