Gus
Wobble under braking
whilst braking from round 120 k or so, my car wobbles, the steering wheel wobbles...not very fun.....it ONLY happens under braking and ONLY at relatively high speeds.....im maybe thinking warped brake discs but my front ones are relatively new, and it has only just started doing this in the last couple of weeks....any suggestions? its irritating me!
sounds like the discs Gus.
The stock ones are shite, too small and too thin to dissapate the heat generated at higher than normal speeds.
what are you doing driving at 120 anyway!!
it was on my own private driveway glenn...i wouldnt be speeding! your a persuasive bastard arent you! your brakes wouldnt fit under my bottlecaps thank god...my student OD doesnt like you! and when you say discs...you mean warpage?
you mean warpage?
y0u m0ve t0 the b0nus stage y0!
when the discs cant get rid of the heat easy enough they tend to warp, some even crack!!
get some dba slotted rotors, not drilled (apparently they warp easy to)
Well I did have some wheels that went over them.
Sorry Gus, don't mean to tease.
But yeah, sounds like your discs aren't up to the abuse.
The only real solution (not bandaids) is bigger wheels and bigger brakes, or, drive like a granny.
Guest Spargo
0h snaP!
Glenn, are ahem still for sale? Could they be fitted in a day, say?
The Brakes Sam??
Prolly allow 2hrs, stuck bolts etc...
You may want to check your MC size, I thought the later E30 had a bigger one than my stock one?? I'm running a E32 750il MC. They are only $350 brand new anyway.
