dc2r 0 Report post Posted May 15, 2007 Just need a quick answer on weather a speedo cluster out of a 83' e30 will fit into my facelift 88'? cheers Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted May 15, 2007 AFAIK, as long as it is for the same motor it will work (ie 325, 320 etc) You may want to be a bit picky if you need one with cruise control and OBC take-offs as some had them and some had the pins but no harness (so just need the harness) and some didn't have it at all - same with service indicator lights. Will knows all the ins and outs so maybe ask him about what you need and what is available and he should be able to tell you if it'll work. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 15, 2007 Just need a quick answer on weather a speedo cluster out of a 83' e30 will fit into my facelift 88'? cheers Quick answer no - The fuel guage wont operate when putting early dash into late -even when same cylinder configuration Quote Share this post Link to post Share on other sites
