jpp 0 Report post Posted May 24, 2007 LHS wiper on my 1994 320i coupe doesn't fully work. Motor seems to want to work, but it won't move. Why possible solutions?? Cheers, Jared. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 24, 2007 Try tightening the 13mm arm nut with the wipers in the parked position Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted May 24, 2007 Try tightening the 13mm arm nut with the wipers in the parked position Good idea! Also, I'm new to e36ers, why do the windows wind down when doors open etc? What do the 1000+, 100, 10 etc buttons on the OBC panel do? Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted May 24, 2007 (edited) Good idea! Also, I'm new to e36ers, why do the windows wind down when doors open etc? What do the 1000+, 100, 10 etc buttons on the OBC panel do? I presume your e36 is a 2 door. The windows come down slightly so you don't have to be a muscle man to close the door. The 1000/100/10/1 buttons are for adjusting the clock/date/etc. Edited May 24, 2007 by my_e36 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 24, 2007 Good idea! Also, I'm new to e36ers, why do the windows wind down when doors open etc? What do the 1000+, 100, 10 etc buttons on the OBC panel do? Get an owners manual.....about $30 Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted May 24, 2007 Windows roll down slightly when you open the door so that when you close it, firstly it will prevent the surrounding rubber seals to get worn out quickly. Secondly, I've heard it's something to do with pressure inside the cabin - the door will be easier to shut because the cabin pressure = outside pressure. But, that sounds a little BS to me because Sedans can close fine without the window rolling down - unless the lack of a frame around the window on the Coupe makes it flex more hence the difference in pressure will strain the glass. Quote Share this post Link to post Share on other sites
