nzdesi
E36 Over Heating
hey guys i hav 318 ti 1995 Bwm its over heating for some reason dot really knw why!
well first the air con didnt work but after few weeks i serviced it ma self the air con started working but radiator fan stoped, thn i found out that if i turn on air con the fan started it self. now i hav replaced thermosat and still over heating. i dont know if its water pump well water pump is belt driveen, so i dnt think its ny thing to do with aircon and fan. if u knw whts wrong plz let me knw ny help will be good
The fan is for the a/c system only.
Have you checked that water pump isn't leaking.
Leaking valve cover gasket will be my first suspect.
Edited by 318Touring
Did you flush your coolant system out correctly? This can leave air in the pipe work and not cool properly.
Also could be fan's bearing not effective, and water p[ump as mentioned.
