savvi
firing order help
is the firing order on the m20 b2.5, 153624 from the front cylinder
coz just got some new leads and plugs, hasnt been started in 3 months as well
its turning over allrite but just wont start also doing a bit back firing as well
everything is hooked up correctly triple checked everything
cheers shane .
Edited by E30 bandit
Check your rotor and cap Shane. Also check coil hasn't gone belly up.
Will
Shane, get a honda
<_<
