Guest Zwilling Report post Posted May 3, 2004 HELP, i'm getting water on the passenger side floor and I can't find the source of the leak. I've pulled out bung under the carpet but after it rains the carpet foam is retaining alot of water. It's definately rain water and I don't have a sunroof and I can't see any rust or obvious holes in the firewall??? Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted May 3, 2004 It's not coming through the door panels at all is it? I have not had this problem on my Bimmer, but did have it on a previous car. Water was getting inside the doors and leaking into the car (and not draining out the bottom of the door). Cheers Quote Share this post Link to post Share on other sites
Guest Zwilling Report post Posted May 3, 2004 I've not been able to trace the leak. The panels are dry and the seals around the windows and door aren't cracked. I looked through the forums on the us bimmersport site for the same problem. There were a a few entries there involving gutters, firewalls, and blocked drainpipes but the descriptions of where to find them doesn't seem to apply to my model, argh! Right now i'm managing by propping up the foam off the floor using wood strips so that the water drains out through the bung hole instead of soaking into the carpet, not exactly a prof. job but if it's not fixed the carpet will rot Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted May 5, 2004 heater hoses in tacted?? bro, coming to jays bar 9pm on the 12th(in j ville) Quote Share this post Link to post Share on other sites
Guest Zwilling Report post Posted May 5, 2004 (edited) All I can say is it's definately rain water. Next trick will have to be ripping out the carpet and pouring water over it until I can spot the source. Uh, what's happening there in jville?? Edited May 5, 2004 by Zwilling Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted May 5, 2004 Zwilling said: Uh, what's happening there in jville?? check out meetings thread Quote Share this post Link to post Share on other sites
Guest Zwilling Report post Posted May 16, 2004 Problem solved. Lifted up the carpet completely and followed the rust trail to a pinhole in the firewall right where the wheel arch meets the wall below the glovebox. A little bit of rust was the culprit, my first piece of rust Anyways, removed the glovebox and used the good old sellys to plug the gap for now. Lifted out the seat to dry the foam, what a mission. Quote Share this post Link to post Share on other sites
