PBOY23
INTAKE ON A E36
hi there im thinking of importing this system mainly just the heat shield around the whole thing wich is factory oem plastic with a oem rubber gasket on the top to seal it when bonnets shut . can i expect much from this i want it to have a good sound ive got the piping and pod already , if anyone knows a cheap way or where in nz you can source this it would be much a help to me i think its 150 for the shield delivered cheers (the picture shows an m3 but its to suit a 320/5/8
Posted Image
Posted Image
  3pedals said:
None of the intake bits in the pic are OEM , the manifold is same as 328 as it is a US M3. OEM air box is same as 328
You will gain noise and about 1 kw depending on engine size - do it if you want the noise
ok well it states oem plastic an gasket i have a 320i the one in the picture is diffrent im just wanting to buy the heatsheild/suround
its better than having no heat sheild....but honestly just buy a CF one from autopassion for $175...sounds badass and its carbonfiber so thats gotta be kool right?
I have a 320i just like you... an intake would just make noise and perhaps make the engine more responsive or lively, but it's just for noise really, don't do it for power. I think the word OEM is being misused in that case.
hmmm...where bouts do i find these guys? o have a pod filter thats unshielded...makes a heap of difference but could be better with a shield :D
http://www.autopassion.co.nz
  3pedals said:
show us the dyno results
its been established that the intake doesnt do much....it just looks kool and sounds kool
