PBOY23 0 Report post Posted June 2, 2007 hi there im thinking of importing this system mainly just the heat shield around the whole thing wich is factory oem plastic with a oem rubber gasket on the top to seal it when bonnets shut . can i expect much from this i want it to have a good sound ive got the piping and pod already , if anyone knows a cheap way or where in nz you can source this it would be much a help to me i think its 150 for the shield delivered cheers (the picture shows an m3 but its to suit a 320/5/8 Quote Share this post Link to post Share on other sites
PBOY23 0 Report post Posted June 2, 2007 3pedals said: None of the intake bits in the pic are OEM , the manifold is same as 328 as it is a US M3. OEM air box is same as 328 You will gain noise and about 1 kw depending on engine size - do it if you want the noise ok well it states oem plastic an gasket i have a 320i the one in the picture is diffrent im just wanting to buy the heatsheild/suround Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted June 2, 2007 its better than having no heat sheild....but honestly just buy a CF one from autopassion for $175...sounds badass and its carbonfiber so thats gotta be kool right? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted June 2, 2007 I have a 320i just like you... an intake would just make noise and perhaps make the engine more responsive or lively, but it's just for noise really, don't do it for power. I think the word OEM is being misused in that case. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted June 3, 2007 328imobbin said: its better than having no heat sheild....but honestly just buy a CF one from autopassion for $175...sounds badass and its carbonfiber so thats gotta be kool right? hmmm...where bouts do i find these guys? o have a pod filter thats unshielded...makes a heap of difference but could be better with a shield Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted June 3, 2007 E36 325 said: hmmm...where bouts do i find these guys? o have a pod filter thats unshielded...makes a heap of difference but could be better with a shield http://www.autopassion.co.nz Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted June 3, 2007 3pedals said: show us the dyno results its been established that the intake doesnt do much....it just looks kool and sounds kool Quote Share this post Link to post Share on other sites
