otagomed 0 Report post Posted June 7, 2007 Thanks for your help with questions I had last time. I found icemag forum very helpful as well. While I was researching I came across the word 'DSP' regarding my audio unit. What does it stand for? Dolby surround processor is the only term i can think of. Am i right? How do I know if my 99 328i jap nav unit is DSP or not? I found this thing calle Blitzsafe's BMW/AUX DMX V.1 and depends on whether I have DSP or not I need to order different thing. It says "Blitzsafe's BMW/AUX DMX V.1 allows you to easily add one auxiliary source to the factory CD Changer port. Virtually a plug-n-play installation, you can quickly add a portable MP3 or DVD player, satellite radio or any auxiliary sound source to most 1996 through 2004 BMW factory radio (see specific applications listed below). This device plugs into the two pre-wired CD changer connectors (1 is a 3-pin; 1 is a 6-pin connector) in the rear of the vehicle." So as long as I can connect CD changer in my car I also can connect this thing to my car as well i think. Thanks guys. Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted June 8, 2007 Thanks for your help with questions I had last time. I found icemag forum very helpful as well. While I was researching I came across the word 'DSP' regarding my audio unit. What does it stand for? Dolby surround processor is the only term i can think of. Am i right? How do I know if my 99 328i jap nav unit is DSP or not? I found this thing calle Blitzsafe's BMW/AUX DMX V.1 and depends on whether I have DSP or not I need to order different thing. It says "Blitzsafe's BMW/AUX DMX V.1 allows you to easily add one auxiliary source to the factory CD Changer port. Virtually a plug-n-play installation, you can quickly add a portable MP3 or DVD player, satellite radio or any auxiliary sound source to most 1996 through 2004 BMW factory radio (see specific applications listed below). This device plugs into the two pre-wired CD changer connectors (1 is a 3-pin; 1 is a 6-pin connector) in the rear of the vehicle." So as long as I can connect CD changer in my car I also can connect this thing to my car as well i think. Thanks guys. DSP stands for digital sound processing as far as i know, and its also the first 3 letters on my no. plate haha... Hope this helps anyway. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 10, 2007 How do I know if my 99 328i jap nav unit is DSP or not? It will only be DSP if a) you have the TV and/or nav option the "DSP" menu is visible on the TV screen They didn't fit the DSP amp (Digital Signal Processing amp) to the non-TV/nav equipped cars DSP tended to be fitted to the top-end 5-series (like 540i) and the 7-series, with nav/TV Jochen Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted June 14, 2007 You can get DSP on 7's with no tv or nav. You get a funky little screen next to the tape deck instead of the snazzy coin holder that I have. Quote Share this post Link to post Share on other sites
MattA 162 Report post Posted June 14, 2007 Doe's this mean "AUX" channel on my TV could support an external device? which leads to my next Q where would the connection be? cheers Matt Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted June 14, 2007 Isnt the Aux connection in the glovebox ? Quote Share this post Link to post Share on other sites
MattA 162 Report post Posted June 14, 2007 Thanks Penry, will have to have a look. It's a bit like Aladins cave finbd somethiong new nearly every time I get in it... cheers Matt Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted June 14, 2007 I dont know its there for sure, it all depends on what car you have. If you fill out the ride section on your profile then it would show up just under your name on the left and we could all do a search on the web then Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 16, 2007 Doe's this mean "AUX" channel on my TV could support an external device? which leads to my next Q where would the connection be? Yes, you can connect any device to the AV IN of your TV tuner Camera, play station, x-box, DVD player, etc Bear in mind the input is mono only Video can be PAL, NTSC or SECAM The connection is on the connector of the video module, in the boot. On the 5-series E39, the AV IN is not cabled out. On the 7-series E38, the AV IN and AV OUT are cabled to the rear of the centre console, in the back seat area. If you want cabling etc i can help. Quote Share this post Link to post Share on other sites
