barf 0 Report post Posted June 23, 2007 fuel injection computer is playing silly buggers. scoped the inj banks and they stop firing randomly. had to drill out rivets to get inside the thing, pressing gently on PCB will make it misfire (no inj pulse), the foam inside the case has bent the PCB i think thats the problem, but dry solder joints dont help I hope not all BMW's computer are this bad. anyone had to fix one of these before? mostly discrete components just hoping someone had been here before, or should i just throw it away? I could put my Megasquirt II on it. anyone installed a MS on an old BMW here? was there much trickiness involved? Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted June 23, 2007 mops has. there is alot of information about using megasquirt on e30's over at www.e30tech.com Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 23, 2007 fuel injection computer is playing silly buggers. scoped the inj banks and they stop firing randomly. had to drill out rivets to get inside the thing, pressing gently on PCB will make it misfire (no inj pulse), the foam inside the case has bent the PCB i think thats the problem, but dry solder joints dont help I hope not all BMW's computer are this bad. anyone had to fix one of these before? mostly discrete components just hoping someone had been here before, or should i just throw it away? I could put my Megasquirt II on it. anyone installed a MS on an old BMW here? was there much trickiness involved? I have a 323i ECU if you require PM or 027 6146607 Cheers Grant Quote Share this post Link to post Share on other sites
HELLBM 1691 Report post Posted June 23, 2007 ECU $60.00 Regards Ray 0212HELLBM 0212435526 Quote Share this post Link to post Share on other sites
barf 0 Report post Posted June 23, 2007 thanks guys but i fixed it, resoldered some poor joins on parts of the PCB and shes right now. Quote Share this post Link to post Share on other sites
