CHEMISTRY 0 Report post Posted June 26, 2007 I'm looking for a 2.8 M52tu twin vanos engine for my 2000 728i. Anyone know of one available. Cheers. Quote Share this post Link to post Share on other sites
CHEMISTRY 0 Report post Posted June 26, 2007 Apparantly it is not a simple swap. I'm mechanically illiterate, but I have been told by the mechanic working on the car that it probably wont work. Issues with non-compatibility of the intake manifolds, sensors, ECU unit etc. He has not done a swap. Does anyone know for sure. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted June 27, 2007 Apparantly it is not a simple swap. I'm mechanically illiterate, but I have been told by the mechanic working on the car that it probably wont work. Issues with non-compatibility of the intake manifolds, sensors, ECU unit etc. He has not done a swap. Does anyone know for sure. You are well informed...these late model vehicles are very specific....down to the month of build for engine replacement compatibility, due to Canbus operating systems. You will need to get exactly the same as you have, otherwise it just wont work. Cheers Glenn Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted June 27, 2007 could he not swap over the different parts? eg incompatable sensors or manifolds? (assuming he still gets an M52B28tu? Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted June 27, 2007 could he not swap over the different parts? eg incompatable sensors or manifolds? (assuming he still gets an M52B28tu? I'm afraid not Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 27, 2007 You can get an M54 TU B3.0 which has more torque for about the same money and will be a much better engine in your heavy car Raymond at European autospares, Auckland has 2 at the moment how much did he want for them? Quote Share this post Link to post Share on other sites
sami911 0 Report post Posted July 13, 2007 you need to put the same engine as you have in you car , otherwise you face too much troubles sam /bmwparts/ 0800 BMW 992 OR 579 3331 Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted July 13, 2007 Around 3 grand each Not bad Gus....... Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 13, 2007 yeah thats pretty good, found some good sh*t here, trying to find somewhere to put it! Quote Share this post Link to post Share on other sites
