sven007
Stuffed up rear lights
Hi, I have a major problem, I was an idiot and took out the old e36 4 door rear lights and put in new aftermarket rear lights. The major problem is that I cant remember where the exact wiring goes for each part of the light. All the wires are different colours and was hoping that someone could possibly help me out and take a photo of one sides of their rear lights so I know where to put mine back into the right order.
Have searched google and cant find anything, im not that great in this area as you can see.
problems are that park lights arnt working, and things dont seem to be right eg when lights a=are on the high stop light on the window goes on as well??!!
Thanks heaps for any info on how to sort this out.
Regards
Sven
I don't have a diagram, can't be arsed taking a pic, but also check you havn't blown a fuse dude.
Did you not just have to plug in the old wiring harness???
If you get really stuck use a multi meter to test which wire is which, and which pin on your light goes to which bulb fitting.
