parriehunter 0 Report post Posted July 14, 2007 hey my e30 has always had really crap dim lights...i have tried afew different bulbs and cleaning the glass...but they didnt help much. what bulbs do you guys and girls use? or any other ways to much them better with failing a wof. Cheers Gareth Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted July 14, 2007 You mean they are dimmer than other E30s that have the same standard bulbs, and same headlights? If so, then it must be your wiring. Perhaps it isn't getting sufficient wattage. Quote Share this post Link to post Share on other sites
parriehunter 0 Report post Posted July 15, 2007 I have never actually compared them to another e30....are they all crap...cos with them on dim i can see about 20 metres of the road in front...which i assumed would be crap and just me. i might have to trace the wiring. cheers. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted July 15, 2007 Yeah mine are real dim too makes driving on a open highway difficult its better off driving with no lights on... Quote Share this post Link to post Share on other sites
m_power 0 Report post Posted July 15, 2007 I think most are crap (well from the e30's iv owned anyway). Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted July 15, 2007 most lilky crappy reflector inside headlight , the silver falls off Quote Share this post Link to post Share on other sites
parriehunter 0 Report post Posted July 15, 2007 Ok. I will have a look into all of that. Yea i know what you mean about driving with the head lights off. Thank you all. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 15, 2007 Ok. I will have a look into all of that. Yea i know what you mean about driving with the head lights off. Thank you all. From your ride (1990 320) it will have projection lamps for low beam. When you say you have cleaned the glass - do you mean inside or outside? These lamps are notorius for a smokey discolouration build up on the inside of the glass & on the projector lens itself which causes at marked deterioration of light output. They can look ok but but once cleaned - makes a big improvement. To clean: Remove the lamp & dismantle from the back to gain access. Use clean cloth to clean both projector lens & inside of glass. If properly clean & with good reflector these lamps work well. Also headlight alighnment is critical. Quote Share this post Link to post Share on other sites
Jammasterjames 0 Report post Posted July 15, 2007 (edited) Even my 97 E36 has crappy orange dim light....(tha interior) Edited July 15, 2007 by Jammasterjames Quote Share this post Link to post Share on other sites
