jjs
E36 328i gearbox issues
Im looking at a 328i 1995 import with a gearbox issue....
When changing from first to second it at times won't do so until high revs (about 5-6). If you let off the accelerator it will change fine. There are no other gearbox issues apart from this.
Is this terminal? You experiences?
Does this happen only when cold engine or does it all the time?
Sport mode?
Only when cold, there is a bit of a jolt when changing from 1st to 2nd also
They do chage at higher rev in cold than in warm, but mine's (97 323i) change at 3000 usually but at around 3500-4000 at most even in sport mode. (why would you use sport mode with a cold engine anyway?)
I don't know how bad of a jolt is yours but mine does a little bit when cold as well. The import does it because they always sits in traffic jam and use the 1st and 2nd all the time.
Edit: typo
Edited by my_e36
