Gus
knock knock knock...
well i thought this was my control arm ball joint...but i just replaced it so its not! i have a very very annoying knocking sound coming from my front left side....happens when the road is bumpy...its really pissing me off and i hope its not doing any harm...suggestions?
same deal, only back driver side, happens anytime theres a shift in weight, this dosent even need to be cornering.. even whislt accelerating... :(
from front will be tie rod ends from the end of the steering rack - does the knock go away under light braking?? then probably trailling arm bush (under drivers feet) or sway bar bushes - i've replaced all these on threeta - nearly quiet now!!
or.... the lower ball joints - but wof check will pick these up. see chris at Centreline in new north road - he fixed my car
on the left i have new inner and outer tie rods, new control arm, new control arm bush....i think it may be the sway bay bushing as it looks sweet but could still be knocking round a bit
yes it does, it only knocks when im acellerating and driving normally and knocking stops when im braking... so anyone got any ideas what it could be?
