mackt 1 Report post Posted August 26, 2007 Thought this was really useful to have on this site. [Thanks to edd_jeddie at www.e36coupe.com] might save breaking bits. There are 8 screws that need to come out. The top 4 allow you just to remove the airvents and lock mechanism for the glovebox. Don't forget the 2 hiding under the small covers - flick out with a small screwdriver. The lower 4 will allow you to remove the glovebox to expose all the electronic goodies hiding behind the glovebox. You will need to remove two wires for the glovebox lights. To reassemble I found it really easy to attach vents back to glovebox and slide the whole lot back into place. Tim Quote Share this post Link to post Share on other sites
Jaredsc 0 Report post Posted August 26, 2007 Do you have a weird looking switch on the LH corner inside the glovebox? I do, and havent a clue what its supposed to do. Quote Share this post Link to post Share on other sites
str8_6 277 Report post Posted August 26, 2007 (edited) Do you mean the plug for the rechargeable torch? Edited August 26, 2007 by str8_6 Quote Share this post Link to post Share on other sites
Jaredsc 0 Report post Posted August 29, 2007 No, not a plug, just a large switch. Looks like something you would find on a commercial machiene. I assume its supposed to switch somthing on/off. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted August 30, 2007 Thought this was really useful to have on this site. [Thanks to edd_jeddie at www.e36coupe.com] might save breaking bits. Site no-longer works? Can you point me further into the site, not just the home page? Thanks. No, not a plug, just a large switch. Looks like something you would find on a commercial machiene. I assume its supposed to switch somthing on/off. Sure its not the light on/off switch? Does it look factory or aftermarket? Quote Share this post Link to post Share on other sites
mackt 1 Report post Posted August 30, 2007 Hi try this link http://www.e36coupe.co.uk/forum/index.php?...835383b34b0f9a7 Tim Quote Share this post Link to post Share on other sites
Jaredsc 0 Report post Posted August 31, 2007 Hmm, looks a bit big to be that. I thought maybe it had something to do with the seat heating, as I am sure mine doesnt work. I think it could be the fuse though because both of them dont seem to. You press the button, it illuminates, but then flicks off after a few seconds. Quote Share this post Link to post Share on other sites
