Cale 36 Report post Posted September 13, 2007 (edited) Another annoying little Question. Has anyone taken the lining that sits under the sunroof off? I've got as far as to undo clips at the front of sunroof and at the back but there is a little bracket that slides along with the lining that doesn't want to come off. [edit] on a e30 Edited September 13, 2007 by Quailboy Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted September 13, 2007 Another annoying little Question. Has anyone taken the lining that sits under the sunroof off? I've got as far as to undo clips at the front of sunroof and at the back but there is a little bracket that slides along with the lining that doesn't want to come off. [edit] on a e30 just slide the vinyl panel back after pulling the clips down . then tilt up and unscrew the metal sunroof panel .then remove the vinyl panel and plastic arms that are clipped in Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted September 13, 2007 Oh, that easy? Cheers Brent, will have a go tommorrow. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted September 13, 2007 It sounds easy but be prepared to spend plenty of time to get it right. When you get it back togther go slowly when closing your sunroof again to make it tracks properly. You risk tearing your lining if you dont. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted September 13, 2007 Guys, what type of bit do you use for the bolts in the sunroof? They're like allen keys but allen keys don't work. And Ive broken 2 size 4 flat bits on them. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted September 14, 2007 Don't worry. Just found some in my drawer. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted September 14, 2007 Don't worry. Just found some in my drawer. Male Torx. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted September 14, 2007 Yea, figured that out after a lot of swearing and throwing things around. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted September 14, 2007 Yea, figured that out after a lot of swearing and throwing things around. Hope you save some of those words for when you have to put the whole thing back in again Quote Share this post Link to post Share on other sites
