Boost Junky 1 Report post Posted September 16, 2007 Drive shaft front section from a e28 525 manual gearbox to bolt to a ZF 5 Speed Gearbox E21 mounts Gearbox mounts the two rubber bits that bolt to the bottom back bit of the gearbox Cheers, Luke Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted September 16, 2007 Try Trademe member Gigikim Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted September 16, 2007 Try Trademe member Gigikim Cheers mate ill have a look ive seen them on there before Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted September 17, 2007 Drive shaft front section from a e28 525 manual gearbox to bolt to a ZF 5 Speed Gearbox E21 mounts Gearbox mounts the two rubber bits that bolt to the bottom back bit of the gearbox Cheers, Luke Gidday Mate , just check the comptability of the e28 shaft with your zf box before you buy, the pcd of the rubber guibo (doughnut) may be different. Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted September 17, 2007 Gidday Mate , just check the comptability of the e28 shaft with your zf box before you buy, the pcd of the rubber guibo (doughnut) may be different. Oh yea i'll check that out thanks dude uve been very helpful Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted September 20, 2007 Anybody.... Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted September 23, 2007 (edited) Just need a drive shaft front section from a e28 525 manual gearbox now. I know they are hard to come by but if anybody has this please let me know, need it asap Cheers, Luke Edited September 23, 2007 by Boost Junky Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted September 23, 2007 I got mine form BM warehouse in Hamilton, they are two companies now I think Mosen Bmw or something they found one no problems, someone will get you the details Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted September 23, 2007 Cheers Jonty. I think Mosen Euro is seperate but Kevin Mosen does not run it anymore he sold up (correct me if im wrong anyone) but thats what i have heard. My E30 is from there. Im just gonna wait till my gearbox and motor are all in then measure the length that i need the driveshaft to be and the spline count on the hanger bearing end and the pcd spacing on the gearbox end then will know for sure if i need that specific half of driveshaft Quote Share this post Link to post Share on other sites
