madandy
BUild plate location
OK so I've searched the forum and the net and my engine bay now where the hell do BMW put the build plate with colour code, chassis code, engine & trans details?
Exactly what i've been wondering. Or is there an online vin decoder that is really comprehensive?
They don't. Colour code is on a sticker on the front shock tower (usually passenger side). The SA built cars have a build plate above the drivers headlight and/or a chassis number stamped into the shock tower. Other cars have a chassis number stamped into either the same place or on top of the firewall. The sticker on the drivers side b-pillar that specifies tyre pressure is often accompanied by stickers/stamps with build dates and other info. The VIN is the main source of info.
I got this for my VIN:
Chassis number NA29593
Vehicle code CD18
Series E36
Model 328i
Body type saloon
Catalog model ZA
Production date 1998 / 01
Engine M52
Transmission Manual
Steering Right
Catalyzer YES
Additional Information for Vehicle code CD18
Production FROM : 1997/09/01 TO : 1998/11/30
Engine M52
Engine Oil 6.50 Liter
Transmission Manual
Transmission Model S5D 320Z
Transmission Oil 1.30 Liter
Rear Axle Oil 1.70 Liter
Coolant(w/o Air Conditioner) 10.00 Liter
Coolant(with Air Conditioner) 10.00 Liter
Brake fluid 1.00 Liter
Remarks :
Final drive (rear axel), manual transmission: lifetime oil filing
BTW that's mostly e30 info (my post). e36 may be different - just realised that's what you drive.
Edited by bravo
All good Bravo. you answewred me well, thanks.
What I really wnated to find out was if my M52 was a M52TU28 or not and if it was a 142kw 280NM or 140kw 275NM model or a 142kw 280NM @3500 to 5500 engine if ya get my meaning.
cheers
Andy
M52TU engines starts in the e46 range. The gain comes with the dual VANOS which control the exhaust side as well as intake rather than just intake side on single VANOS on the non-TU engine.
