Damo 23 Report post Posted September 17, 2007 Need to go to 5 lug to find wider wheels, so I am after regular E36 front spindles (king pins) and hubs - maybe the wishbones also. Then for the rear I need a set of E36 compact (318ti or 323ti) rear hubs. Thanks in advance! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted September 18, 2007 Need to go to 5 lug to find wider wheels, so I am after regular E36 front spindles (king pins) and hubs - maybe the wishbones also. Then for the rear I need a set of E36 compact (318ti or 323ti) rear hubs. Thanks in advance! i have e36 front hubs etc as you know .021433600 Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted September 18, 2007 Then for the rear I need a set of E36 compact (318ti or 323ti) rear hubs. Thanks in advance! I have a complete Ti rear end minus diff head. You for the taking if you pick it up or sort the freight from Paraparaumu. It has one bent arm but you don't need it so all good. Quote Share this post Link to post Share on other sites
