Damo
e36 front spindles/hubs & e36 compact rear hubs
Need to go to 5 lug to find wider wheels, so I am after regular E36 front spindles (king pins) and hubs - maybe the wishbones also. Then for the rear I need a set of E36 compact (318ti or 323ti) rear hubs.
Thanks in advance!
Thanks in advance!
i have e36 front hubs etc as you know .
021433600
Thanks in advance!
I have a complete Ti rear end minus diff head. You for the taking if you pick it up or sort the freight from Paraparaumu. It has one bent arm but you don't need it so all good.
