bmw.maniac
e30 Temperature Gauge
Hi,
My new e30 seems to run a bit hotter than other cars I have owned. When I start it the temp is in the blue, but this quickly rises to around half way in around 10 minutes. Is this normal, or is it something I should be worried about.
Btw, it's a '88 318i Manual, and has recently had the radiator replaced.
Cheers.
E30s should be at normal operating temperature at half-way.
I've owned some that only went 1/4.
if it has a new or good thermostat , temp normally goes up quickly to half way
