EVLE30 0 Report post Posted September 24, 2007 (edited) hi guys, i was working on the car yesterday, and dicovered that the ECU is a motronic one... in my understanding i believed that the FL E30 ran the jetronic? my car (ever since i got it) barely gets 350km's out of a tank. could this have something to do with it? edit: for a moment there i had a brain fade... forget this thread!!!! Edited September 24, 2007 by EVL318 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 24, 2007 no all M40 engines are motronic only the old M10 1.8 ran L-jetronic. check afm , vac leaks if you are not getting good ecno Quote Share this post Link to post Share on other sites
EVLE30 0 Report post Posted September 24, 2007 no all M40 engines are motronic only the old M10 1.8 ran L-jetronic. check afm , vac leaks if you are not getting good ecno cheers mate, what do i need to look for or chek with AFM? and will check for vac leaks, no you mention it i can hear air escaping somewhere.... Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 25, 2007 try a replacement afm (i have one) Quote Share this post Link to post Share on other sites
Tomo 0 Report post Posted September 25, 2007 my f/l 318i manual gets 450km+ a tank and my sisters f/l e30 auto gets around 350km as with yours. aside from the transmission difference i know the oxygen sensor is gone in hers, could be causing you to get worse economy also? Quote Share this post Link to post Share on other sites
