325_driver
m20 b20 + manual trans
When i do my engine transplant i will have a spare engine lying arround
Engine from the e30 320i goes sweet
perfect manual transmission
could supply diff and drive shaft at additional cost
cheers
cheers
Hi if the gearbox is the 240 i'd be happy for first refusal. is the engine a FL model ?
Thanks
Mark
will check on what the gear box is, gotta get under the car first.
im looking for atleast 500 for the box and engine
it is from a pre face lift model, which im sure will fit a face lift model any way
i think the engine mounts are just a little bit lower or some thing
will get back to you on what model the box is
Thanks, if you will take $500 and the gearbox is the correct one then i am happy to buy it from you.
Mark
will check when i get home, do you just want the gear box?
i will tell you how much i am actually selling it for
i said at least 500 for engine and trans, probably want a bit more, since its costed me a bit
will let you know
will let you know
Happy to buy both, but if you want to give me a price for each seperately then thats fine too.
